CL72 steering head gap on front forks
mips
Post by mips » Thu Jun 06, 2013 7:12 pm
I'm putting back together a '65 CL72.
I put new races in it, made sure the bottom washer and seal were on.
But, there is a healthy gap between the handlebar bridge and the nut below (dust seal that holds the balls in). I did notice that when I get the triple tree snug, but movable, that I can see some threads above the dust seal. I'm not sure if maybe I beat the lower bearing cup down too low?
I was starting to think maybe I have my fork tubes too high? Any ideas?
Re: CL72 steering head gap on front forks
Post by LOUD MOUSE » Thu Jun 06, 2013 8:07 pm
If you have a parts book you may want to be certain all the parts are installed. .....lm
mips wrote:I'm putting back together a '65 CL72.
mips
Post by mips » Thu Jun 06, 2013 9:15 pm
I checked again and everything is there. Only doubtful thing i can think of is is whether I have correct washer under the cap nut. The washer i have is about .002"
The gap I have is roughly .08"
Post by LOUD MOUSE » Thu Jun 06, 2013 9:18 pm
Do you say you replaced the ball/rollers with TEMKIN?. ................lm
mips wrote:I checked again and everything is there. Only doubtful thing i can think of is is whether I have correct washer under the cap nut. The washer i have is about .002"
mips
Post by mips » Thu Jun 06, 2013 9:28 pm
No sir, I bought Honda oem stuff from classic Honda restoration. I didn't replace the ball bearings themselves because I had 37 good ones.
mips
Post by mips » Thu Jun 06, 2013 9:41 pm
One thing I though was peculiar was that once I cinched the superior dust shield down, I could see a few threads above the dust shield visible.
