Points Plate Screws
sibes67
Points Plate Screws
Post by sibes67 » Fri Nov 09, 2012 5:39 pm
These are listed as 5 mm I believe, what is best and quickest way to get a couple of new ones? Finally got the top one out, but the philips head is pretty well shot now. Thanks.
sibes67
Screws found
Post by sibes67 » Tue Nov 13, 2012 4:07 pm
found them in the metric section at a True Value Hardware store, good on that.
one problem remains > keep stripping top screw on right side breaker points, couple threads are chewed down after loosening once, then re-tightening...
wonder if I should try to find a new breaker plate?
are 2 washers required on each contact breaker screw? Thanks for any input.
Ron
Re: Screws found
Post by LOUD MOUSE » Tue Nov 13, 2012 6:11 pm
If the screw you use is too long it will hit the head and strip. .......lm
sibes67 wrote:found them in the metric section at a True Value Hardware store, good on that.
Ron
sibes67
Re: Screws found
Post by sibes67 » Thu Dec 20, 2012 8:00 pm
LOUD MOUSE wrote:If the screw you use is too long it will hit the head and strip. .......lm
Ron
So I need 93500-0601802 6 X 18 Screws Anybody got a couple to buy? These are the screws for the contact breaker points...ones I got are still too long. Thanks.
Ron
FluteTears
Re: Screws found
Post by FluteTears » Thu Dec 20, 2012 10:18 pm
Ron
Ron
Time to Cut or gind them down then.
1974 CT90
1964 CA77
Re: Screws found
Post by LOUD MOUSE » Fri Dec 21, 2012 3:47 am
Add more washers. ...........lm
Ron
Ron
sibes67
Post by sibes67 » Fri Dec 21, 2012 5:47 pm
Ground em down, that worked.
Gotta go shovel snow!
Ron
