My speedo is apart....need some advice
68Cb77
Post by 68Cb77 » Tue Dec 13, 2011 12:32 pm
Ok, my speedo is from a 67 Superhawk. It was giving all the symptoms of the grease having gone hard in the speedo. Loud buzzing, needle jumping everywhere. I unplugged the cable fairly quickly and the spring inside the speedo is fine. So I've got it apart, mostly, but now I'm not sure how to get at that grease in the "pot" Anyone got advice? I'm not quite sure how to get at the lube part. Do I need to take this apart further?
67 Honda CB77 Superhawk
82 Honda XR200R
70 Honda CB750 K0
68Cb77
Post by 68Cb77 » Tue Dec 13, 2011 9:32 pm
Anybody? Just wondering, thinking maybe I can just use some WD40/oil? Throw it in there?
82 Honda XR200R
70 Honda CB750 K0
Post by davomoto » Tue Dec 13, 2011 9:45 pm
Do a sear on this site, speedo rebuild "search for all terms". It's all in there , where to and where not to put oil.
Davo
68Cb77
Post by 68Cb77 » Tue Dec 13, 2011 9:51 pm
Thanks Davo, for some reason I have the damnest time trying to figure out the friggin search feature!!!!!! Drives me nuts
82 Honda XR200R
70 Honda CB750 K0
Kigsby
Post by Kigsby » Wed Dec 14, 2011 8:59 am
Thank you Davo! I have had problems with searches as well and just clicking on "search all terms" instead of "search for any term" made such a big difference in the results returned.
Post by davomoto » Wed Dec 14, 2011 11:00 am
Yes, it used to drive me nuts as well! Just by checking search for all terms, you get only the post you want.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
NBD925
Post by NBD925 » Sun Jan 08, 2012 8:00 pm
Now I know this is going to sound obvious but believe it or not I went for a the longest time not know that doing a search for, lets say ( Oil Pump) only realy works well if you type in ( Oil and Pump) putting that word "and" in the middle of each word you want to search for. Also as mentioned above, clicking on the search all terms button below helps alot too.
