mike1969
Post
by mike1969 » Tue Dec 28, 2010 1:33 pm
I picked up an Dream ignition switch with a "T" code. t plus 4 numbers. I have several "T" keys but none will fit into the switch.
Would that denote a problem with the switch or were there different types of T keys?
FAST FRED
Post
by FAST FRED » Tue Dec 28, 2010 4:05 pm
As I remember it the first number after the T is the key blank nunber and the last three numbers are the lock code for depth of cuts. If you have a key that has the same first number it should fit into the switch but won't turn it unless the last three match.
Fast Fred
65 CL77
66 CL77
76 CB550FKR
76 CT90
mike1969
Post
by mike1969 » Tue Dec 28, 2010 4:34 pm
Thanks Fred,That explains it. None of my T keys have matching first numbers. Guess I'll start looking for the correct key.
Post
by davomoto » Tue Dec 28, 2010 4:53 pm
Mike, I have a lot of T keys. What # do you need?
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
mike1969
Post
by mike1969 » Tue Dec 28, 2010 6:08 pm
Thanks Dave,I need a T9644.
Mike
Post
by davomoto » Tue Dec 28, 2010 7:45 pm
Mike, I have 6 T9645s. Don't it just figure!
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
mike1969
Post
by mike1969 » Tue Dec 28, 2010 8:19 pm
Dave,I'll keep those in mind if I can't come up with an exact match and have to do surgery on the switch.
