May not need to remove the valve cover? Just check the mark on the end of the cam shaft is pointing vertically downwards while on the F timing mark?mike horvath wrote: ↑Wed Nov 05, 2025 3:35 pm“Carb was disassembled, briefly chemdipped, and cleaned. All existing jets, needles, seat, etc. were reused. I only replaced the bowl gasket.“
Ok. One more hit on the carb topic;
Did you use canned air or low pressure air nozzle to blow out all air passages?
Not sure the cam chain would jump a tooth, I think there’d be a better chance of it jumping completely off (oh noooo Mr. Bill!) if there’s that much slack in the loop, but you’d not only hear it in the bottom end while cranking, the valves wouldn’t open and close and you might damage the crank.
Man, short of popping the top to see the TDC punch mark, I’ve only one thought;
Might it be possible to remove the plugs, set #1 piston at the top, and see where the timing F mark is? You'd need an extra hand for this one.
68 Dream CA77 won't run
- Muddy
Re: 68 Dream CA77 won't run
Thanks.
Regards
Muddy
'64 C72
'63 C72
Regards
Muddy
'64 C72
'63 C72
- Michael Stoic
- Contact:
I'm going to pile in with the check the static valve timing and ignition timing crowd, but also, I am not a fan of non standard coils and untested capacitors.
Also, check to make sure your plug wires are secure in the plug caps - this can be a weak link.
Not least: are your new spark plugs resistor type? If yes, then a no-no. Use non-resistor spark plugs, at least during the testing stage. The 'barely enough' original ignition system was designed around non resistor plugs and you want to eliminate as many non standard variables as you can.
Mike Stoic
Mike Stoic
hoodooman1
Ok everyone, thanks for the input! Turns out my condenser was bad. I had a backup, and it was bad as well. I ended up cutting the wires off and soldering them onto an aftermarket condenser from a 70 Nova 250L6 I got at the local parts store. So far, its running well. The carb needs a little tuning but I'm real close. The condenser uF rating was .22-.26.
- Michael Stoic
- Contact:
Very good result! Great that you are posting the follow up - a lot of people want to know how issues get solved.
If you have any way to check the capacitance of the old, failed condenser, post that here. It would be a great reference for others doing fault diagnostics.
First principles are a good foundation...
Mike Stoic
Mike Stoic
