Changing throttle cableChanging throttle cableHey guys I am new here and need some help. I am restoring a 1965 CA77 dream. I am wanting to install a new throttle cable, but the bike has an internal throttle twist grip thing, and I do not know how to remove it. The manual I have does not cover, so I am at a loss. Can someone tell me how to change the cable?
TOOLS Hi,
Welcome to the forum., are you also active on the www.hondatwins.net ? To replace the cable you have to disassemble the switchgear which holds the throttle grip. Jensen assembly of Japanese motorcycles requires great peace of mind (Pirsig)
SwitchWhen you take the switch apart be very careful. There is a little flat spring in there that applies pressure to the throttle tube. It will fall right out and will be hard to find. The voice of experience speaking...
