I've slackened off the swinging arm to clean up the footrest plates and wondered if anyone has a torque figure for tightening the self locking nut ?
When I assembled it I did it so the swinging arm would just drop under its own weight but as everything else is in place it would be easier if I could just torque it up.
Thanks in advance,
Phil
CB72 Swinging Arm Nut Torque ?
Re: CB72 Swinging Arm Nut Torque ?
I don't know I've seen a number fore this.
I do as you did after I've pulled down tight on the nut to position all parts then slack back to allow the arm to move without much force. .....lm
Phil-UK wrote:I've slackened off the swinging arm to clean up the footrest plates and wondered if anyone has a torque figure for tightening the self locking nut ?
Thanks in advance,
Phil
