Rim trueing
zoom
Rim trueing
Post by zoom » Sat Mar 26, 2011 12:24 pm
Finished rezincing my spokes and got the rims relaced and trued........I think. I have about 1/16" variance in a few spots on both rims that I can't seem to work out. Spots vary, some up and down, some side to side. Would this be acceptable? Plan to use some dynabeads for balancing tires.
Thanks
teazer
Post by teazer » Sat Mar 26, 2011 1:20 pm
1/16 is within tolerance, but try to eliminate the up and down first. Around the weld there will always be a jog, so ignore that.
Snakeoil
Post by Snakeoil » Sat Mar 26, 2011 7:19 pm
Yeah, Teazer is right about the welded seam on the rim. They do a crummy job of grinding the welds so you always get a jump. New rims are even worse.
But a 1/32 is a better spec to hold than 1/16 inch. If you can get your hands on a dial indicator, it is a much better way to true a rim than to use a pointer.
If a rim is bent a bit from hitting a pothole, it migh require a whack with a dead blow hammer. But that is something best left to experts unless you are pretty good with stuff like this.
regards,
Rob
zoom
Post by zoom » Sun Mar 27, 2011 11:52 am
Thanks for the info. I think I will give it a go the way they are now since they would be in spec. I live in a 20k town and only plan on riding it locally. Thanks
