Can someone tell me how to dissamble the kick start lever?
silverclerk@gmail.com
Post by silverclerk@gmail.com » Sun Feb 20, 2011 5:54 pm
Hello,
The kick start arm on my cb77 is worn out. The little top part (pedal) is fine and the rubber on it looks good so I would like to reuse it. I cannot figure out how to remove the pedal from the arm, any help would be appreciated.
Thanks
Post by davomoto » Mon Feb 21, 2011 10:59 am
You need to push down the washer on top, and there is a circlip in a groove below the washer, If you can get someone to push the washer down while you remove the clip, it really helps.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
