								lhz55
						Post
								by lhz55 » Sat May 31, 2008 10:35 pm
			Hello again,
1965 CB77.  The Frame has one of the rear 4 engine bolt tabs broke off. The missing tab is the top one  near the tool box, left side. The other six ( 3 on top and 3 remaining in the rear) are fine. Do I find a welder to repair the missing bolt hole or can I safely run her on the remaining six?
Thanks, Lee
								Kirk
						Post
								by Kirk » Mon Jun 02, 2008 3:50 pm
			I have a frame in the same shape , hate to toss it it has a title
Let me know if you try and have it welded?
Thanks,
Kirk
			-  Like this?
						Post
								by davomoto » Mon Jun 02, 2008 8:14 pm
			Kirk, your's certainly looks like it could easily be repaired by a capable welder. Worth saving for sure since it's titled! Can't really say on the other without seeing it, but take it to a good welder and see what he thinks.
								lhz55
						Post
								by lhz55 » Mon Jun 02, 2008 8:44 pm
			Kirk, Thanks for the photo. Mine is excaltly like the photo. I bought another frame from Charlie
and the same mount was split. Seems like there should be a common cause for this failure. I will attempt to take before and after pictures on the welding.
Thanks Davomoto & Kirk.
Lee
								Dogsbd
						Post
								by Dogsbd » Mon Jun 02, 2008 10:07 pm
			Seems to me a decent welder could cut the remainder of that tab off, fab a replacement and weld it in place.
								Kirk
						Post
								by Kirk » Tue Jun 03, 2008 11:42 am
			Thank you for your replies Dogsbd, Davomoto and lhz55
Will update on any progress
Thanks,
Kirk
