Kick start lever stuck
roadcapDen
Post by roadcapDen » Thu Jan 06, 2011 8:20 am
305'rs,
1st post, tried searching but not quite sure re cause.
The kick start lever is in the upright position and will only move very slightly, it's stuck, I can hear some noise in the case but I don't want to force it down too hard.
It's in neutral, the pistons are siezed too.
Likely causes??
Thanks,
roadcapDen '65 Dream near Toronto CDA
cyclon36
Post by cyclon36 » Thu Jan 06, 2011 8:33 am
Well, if the pistons are seized, the kick starter is not going to move either.
roadcapDen
Post by roadcapDen » Thu Jan 06, 2011 1:43 pm
Thx Cyclon, Sorry, I meant the pistons WERE seized.
What is the gas line thickness ie OD or ID, wasn't stated in the parts manual.
Post by davomoto » Thu Jan 06, 2011 1:58 pm
Fuel line is 5.5mm ID. Remove the right cover, and see if there's an issue in there. If not, you may be splitting the cases.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
