neutral
Cable luber
Davo, I've been using one similar to the Motion-pro luber for 25yrs..................D
jensen
- Contact:
Don't use it while the tachometer or speedo cable is attached,
Yes, that's the one, I use it for years now, and always good results.@ Steve,
In general lube the cables every year with High Density Telfon spray and a cable lube device, easy and simple. I go on spraying and pumping until it squirts out on the other side (of the cable).
