returning to idle
ccscrambler
returning to idle
Post by ccscrambler » Sun Oct 23, 2011 6:45 pm
I have a 1968 Honda CL77 with the following problem - when revving the motor with the bike out of gear and at rest, the return to idle speed is very slow - sometimes 10 to 15 seconds -
any good solution for this?
Thanks.
Post by G-Man » Mon Oct 24, 2011 2:14 am
Welcome to the forum.
Check and lube if necessary:
Twistgrip
Throttle cable (check for kinks or fraying inner, does the cable have slack at idle?)
Carburetor slides (make sure the springs are returning the slides to the stops)
Re: returning to idle
Post by LOUD MOUSE » Mon Oct 24, 2011 8:00 am
One carb slide is a bit higher than the other.
Check your adjustment. ........lm
ccscrambler wrote:I have a 1968 Honda CL77 with the following problem - when revving the motor with the bike out of gear and at rest, the return to idle speed is very slow - sometimes 10 to 15 seconds -
Thanks.
