carb drain hose
kenkah
carb drain hose
On the bottom of the carburetor there is a fuel line that seem to be a drain. I read through some other posts where it was said that this is basically useless. my problem is is that I have fuel pouring out of the tube. Should I plug the tube or is there a bigger issue here?
Re: carb drain hose
Check your float lever. ...............lm
kenkah wrote:On the bottom of the carburetor there is a fuel line that seem to be a drain. I read through some other posts where it was said that this is basically useless. my problem is is that I have fuel pouring out of the tube. Should I plug the tube or is there a bigger issue here?
- h305 Moderator
Re: carb drain hose
Level...., or the float(s) could be perforated.LOUD MOUSE wrote:Check your float lever. ...............lm
Re: carb drain hose
Or the float needle and seat could be dirty or worn.e3steve wrote:Level...., or the float(s) could be perforated.LOUD MOUSE wrote:Check your float lever. ...............lm
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
