A little bit of an update.
I check the carb - Bowl was clean looked brand new.
Rebuilt the petcock with kit from retro bikes.
Waiting on Air filter and tube to come in.
Put in New NGK D8HA plugs and new boots.
I Tried to start the bike and found that I have no spark whatsoever. I followed the plugs back to a white cylinder shaped item. I found that the terminals on both ends felt warm to the touch after trying to start the bike several times. I assume this is similar to a distributor on a car. Are these known to fail and is there a way to test them?
Newbie update & need help - No Spark
Key in the correct position?
Battery with a decent charge?
Plugs out of the plug holes and grounded with good contact?
Condenser replaced and/or known good and connected?
Wiring harness plugged in well?
Kill switch (little button on the left side hand controls on depressed? (just kidding on this one!)
It will be the simple things that are missed in my opinion :)
CA78 - 3111XX - Frame
CA77E - 3161XX - Engine
kenkah
No Spark
I'm gonna try to trim back the plugs today and see what happens. I did find that in another thread after I had previously posted.
As for the condenser, how to go about checking that?
Also, when you say check the points are you referring to the plugs themselves?
The points (contact breaker points) are under the small cover on the right hand side of the cylinder head. By flicking the points open (ignition on) you should see a spark at a (grounded) spark plug.
