cam bearing clearance
prodigal son
Post by prodigal son » Tue Jan 20, 2026 6:59 pm
As long as the motors apart, the cam bearing do spin nice. If I was to replace them, what clearance are the original bearings? Are they CN or C3 ? Thanks, Gary
Tim Allman
Re: cam bearing clearance
Post by Tim Allman » Wed Jan 21, 2026 10:31 am
I've never really thought about this although I normally replace them if they are old or their age is unknown. The parts book just calls for 6004 bearings, which implies CN, so that's what I have used and I have never had a problem.
I found some guidance here:
https://tflbearing.com/blog/understandi ... rance.html
which leaves me thinking that CN should be used unless there is a good reason not to. In particular, the bearings are not press fit and I think the top of the head is unlikely to get much above 100℃, especially near the ends of the shaft which are in the air stream. That said they also make a pretty good case for C3 as they suggest them for motorcycles and electric motors which are unlikely ever to get as warm as a motorcycle.
It seems that you have a choice but I'm not worried about my bike with its CNs.
