1969 CA77 runs erratically
quidger
Post by quidger » Sat Jul 26, 2025 11:53 am
https://www.dropbox.com/scl/fi/r7brfozc ... 3mwk7&dl=0
https://www.dropbox.com/scl/fi/l8w2bwn5 ... q0bfv&dl=0
Here’s a link to videos of bike running.
Coil tested good. Installed new spark plug s and boots and reset the timing. Carburetor cleaned and ultrasonic cleaned umpteen times.Compression 125/130. Valves adjusted. Minimal smoke from exhausts. Some black , drier soot on plugs.
Bike starts on the first kick every time and the engine runs normally for a short period of time, 4-5 minutes . Slowly the bike loses its idle and then it dies. I tried to adjust the idle screw when it was running to increase the idle and it had little effect on it.When it gets warmed up after five or so minutes of running the bike simply has a decreased idle and dies.
Any thoughts would be appreciated.
S90 / CB550 / CA 77 Dream 305 / Yamaha RT2 360
Tim Allman
Re: 1969 CA77 runs erratically
Post by Tim Allman » Sun Jul 27, 2025 3:14 pm
Things like this are often hard to diagnose but here's one idea.
The throttle cable needs to be really clean and free to move. If it sticks and holds the slide a bit above the idle speed screw it can slowly move and drop the idle speed. WD-40 is a convenient cleaner to inject at the top and catch at the bottom. I use light oil such as 3 in 1 to lubricate the cables.
In the videos the idle speed seems a bit slow. I know you don't have a tachometer so you might want to get a hand held one. (That's what the dimple in the bolt that holds the rotor on the right side of the crankshaft is for.) The recommendation for my CB77 is about 1000 RPM. I doubt yours differs much.
Nick
Post by Nick » Thu Jul 31, 2025 2:45 pm
1. Did you confirm that the pilot jet is clear? That is, did you remove it from the carb, hold it up to a light and confirm that you can see through it. If you can't, remove a single strand of copper wire from a piece of wire and used it to clear the blockage. "I cleaned the carb," doesn't mean much if you haven't visually confirmed that all jets are clear. Ideally, you also want to blow the carb out with compressed air immediately after cleaning. Also confirm that the passageway for the idle circuit is clear.
2. Remove the float needle seat from the carb and check that there is no accumulated dirt, etc. in there.
3 Check float level
4. Disconnect the fuel line and confirm good fuel flow from the petcock.
5. Ensure that the fuel cap breather is clear. Or, loosen the fuel cap if there's not too much fuel in the tank.
6. If adjusting the air screw has no effect on how the bike runs, it means the idle air circuit is plugged. Starting point is one and one-half turns out from fully bottomed, with about a half turn in either direction for best running.
Michael Stoic
Post by Michael Stoic » Thu Jul 31, 2025 4:54 pm
To pile on, in good company, I would add: check the needle position in the slide and the actual size of the carb jet. Make sure both are in spec. Also, you have a nicely painted frame, but the ground connection might be affected. During testing, I'd put some additional temporary ground wires from the coil and battery to the motor.
Mike Stoic
honda305.com/dream/registry
quidger
Post by quidger » Fri Aug 01, 2025 7:55 pm
3 Check float level
My first thought was as pilot jet blockage. After 3 times taking it off of the bike, completely disassembling all jets, etc, ultrasonic cleaning and blowing out all jets, passages and orifices, I’m certain that the problem is not carb/fuel related.
Can you tell me how to check for a defective condenser? It looks like it’s impossible to get to without removing the motor. Any help with a method of checking it on the bike would be much appreciated.
Thanks
Nick
Post by Nick » Sat Aug 02, 2025 9:28 pm
Try removing the mufflers...... If they're the originals they may be plugged up with insect nests, etc. Pull the baffles out also and disconnect the air cleaner. Engine has to be able to breathe.
You might also remove the float bowl, turn on the fuel and see that there's good flow to the bowl.
If you see sparking at the points when the engine is running, that can be a sign of a bad condenser.
There are YT vids showing how to check condensers, but any condenser from a newer bike should be fine, as should any Japanese auto condenser from a 70s era car. I do recall that Triumphs were said to run better with some condensers than others. My Dream was running fine on the original but I plan to replace it with a modern item (not one of those overpriced 'originals').
You can bypass the carb altogether by putting some gas in a spray bottle, starting the engine and squirting some gas into the carb while opening the throttle. If it revs up properly that way you know you've got a carb problem. If the problem persists, it's prolly electricical.
Remember, the more mysterious the problem, the simpler the cause. (And yeah, make sure the engine is properly grounded.)
Tim Allman
Post by Tim Allman » Sun Aug 03, 2025 11:19 am
"Can you tell me how to check for a defective condenser? It looks like it’s impossible to get to without removing the motor"
Yeah, it's in a bad place. I'll bet it made assembly easier though. ;-)
An ohmmeter may be all you need. They often fail by shorting to ground so if the resistance between the case and the lead is less than a few tens of MΩ, i.e. very high, it should be replaced.
As for the value of the capacitor, you will need a meter to do the testing and many multimeters now come with a capacitor tester function. Its value should be somewhere around 0.2μF.
