1969 CA77 Coil
quidger
1969 CA77 Coil
Post by quidger » Sat Jul 19, 2025 1:36 pm
Bike started missing and stumbling after 5 or 10 minutes of riding.
Thought it was carburetor so I thoroughly cleaned it. Same issue. Next time I tried to start it, it would not start at all.
I checked the coil with multimeter and got 4.0 on the primary and 0 reading on the secondary.
Not understanding why I got 0 reading on the secondary reading. Right before I took the coil off the bike I visually checked the spark and the right side looked okay and the left side looked very weak and intermittent.
Wouldn’t the fact that I had some spark, albeit weak, reason that I should get some type of reading from the secondary side.
S90 / CB550 / CA 77 Dream 305 / Yamaha RT2 360
Tim Allman
Re: 1969 CA77 Coil
Post by Tim Allman » Mon Jul 21, 2025 10:20 am
To answer your question, yes, you should see much more resistance on the secondary coil if you are getting any spark at all. And, if the right side was giving a good spark but the left wasn't, it seems to me that there would have to be a problem with the left side connector, wire, cap or spark plug. After all, it's the same coil for both sides.
I have found that problems like this have causes and solutions that are obvious only after trying everything else. All I can suggest is to test all of the parts from the points and capacitor to the coil to the spark plugs. The wires are easily and cheaply replaced but I would use copper wires rather than the almost universal high resistance wires.
