Voltage to ignition
bootleggerjim
Voltage to ignition
What is the correct voltage going to the ignition.....is it 12 volts or less....much thanks guys............
- Tim Allman
Re: Voltage to ignition
The whole electrical system is a nominal 12V system. However, a fully charged lead-acid cell has a nominal voltage of 2.1V so measuring the voltage on a new fully charged battery will show 6x2.1=12.6V. The charging system should push this up to about 14V in order to keep the battery charged although the CB/CL/C/CA/72/77 systems struggle to do this.
Why do you ask?
Why do you ask?
bootleggerjim
The bike I'm working on had the handle bar wires cut...I had to replace the controls with aftermarket ones....there is a black wire with a red strip forward that shows around 8 volts..the other hot ones are 12 volts. ..I didn't know if that wire was going through a resistor for the points......
deuce_7
What year / model bike?
If you’re interested in acquiring reconditioned Honda handlebar controls, please contact me.
1967 CL77 305 Scrambler
bootleggerjim
1964 CB77......
bootleggerjim
Thank you
