How much slack, starter motor chain
tom1104
Post by tom1104 » Wed Jul 17, 2024 4:31 pm
Hello all,
Whats the standard chain slack for the starter motor chain on a CB77. Mine seems to be extremely loose, it touches the casing on the bottom and has about 2cm of movement. Makes quite a noise when starting the bike
Thanks
Tim Allman
Re: How much slack, starter motor chain
Post by Tim Allman » Thu Jul 18, 2024 8:51 am
There is no standard in the service manual but your description tells me that it needs replacement. Sadly these chains get neglected, even though they are easily accessible, because they aren't part of the normal maintenance routine.
Geoff Hastings
Post by Geoff Hastings » Thu Jul 25, 2024 1:18 pm
Even after changing my chain it seemed too loose so I put a shim under the starter motor using some very thin sheet aluminium.
