valve guide Remmoval
thepunisher2007
Post by thepunisher2007 » Sun Feb 17, 2019 3:04 pm
Anyone know how to get the valve guide out of a 305 head. I’ve removed the circlinp and I’m heating up the area but it’s stuck fast. Should I be trying to remove it from the top into the head or the bottom into the barrel opening. Any tips welcome
Re: valve guide Remmoval
Post by G-Man » Mon Feb 18, 2019 5:53 am
You need a stepped punch that fits the bore of the guide and buts against the end. I knocked mine out from the combustion chamber side from memory. Heat helps.
In the picture the tool is shown in the 'wrong' side of the guide. You can see by the shiny surface of the guide and the circlip which way it came out.....
thepunisher2007 wrote:Anyone know how to get the valve guide out of a 305 head. I’ve removed the circlinp and I’m heating up the area but it’s stuck fast. Should I be trying to remove it from the top into the head or the bottom into the barrel opening. Any tips welcome
thepunisher2007
Post by thepunisher2007 » Mon Feb 18, 2019 4:41 pm
thanks. that’s really helpful.
i am however having no luck whatsoever in freeing them. they are stuck fast and nothing i’ve tried so far has even got a small amount of movement.
Post by G-Man » Mon Feb 18, 2019 4:49 pm
There are companies in the UK who will bore out the guides and insert bronze liners.
https://www.fondera.co.uk/classic-bronz ... uides.html
thepunisher2007 wrote:thanks. that’s really helpful.
thepunisher2007
Post by thepunisher2007 » Mon Feb 18, 2019 4:56 pm
that might be and option as i’m out of ideas short of drilling it out
oldbikedude
Post by oldbikedude » Mon Feb 18, 2019 8:09 pm
My guy machines out what he needs to install the new one. He never removes the entire old guide. Does that on everything.
'67 Ca77 Dream
AlanW
valve guides
Post by AlanW » Tue Feb 19, 2019 3:55 am
I do them as G man says, put the head in the oven at 200deg and use welding gloves(gets really hot), an ally drift with a shoulder on it, never fails. Beware wait till the wife goes out before using oven.
Cheers Al.
