CA77 Points oil seal replacement question
garncarz
Post by garncarz » Sun Aug 05, 2018 2:33 pm
My '66 Dream has sprung a leak at the distributor/points oil seal. Would anyone have an instruction on how to remove/replace the seal?
Thanks.
Tim Allman
Post by Tim Allman » Sun Aug 05, 2018 6:33 pm
You can pry the seal out with a small screwdriver or something similar. Just poke it through the side of the seal, not too far or hard to avoid damaging the bearing behind it. When installing the new one it helps to relieve the edge of the hole a bit with a utility knife (to avoid shaving the rubber off the outside of the seal) and lubricating it well with oil or grease. A socket that just fits the outside is a help in pushing it in. I hope this helps.
Re: CA77 Points oil seal replacement question
Post by LOUD MOUSE » Thu Aug 09, 2018 4:50 pm
As you need to remove the points plate you can remove the aluminum cover and drive the seal out then install the new one.
Add a small amount of lube at center of the new seal. ..............lm
garncarz wrote:My '66 Dream has sprung a leak at the distributor/points oil seal. Would anyone have an instruction on how to remove/replace the seal?
Thanks.
garncarz
Post by garncarz » Sat Aug 11, 2018 3:24 pm
I should have used Ed's method. I put a gouge in the seal carrier and now the leak went from a drip to a stream. Shit. Any way to seal up a gouge?
Update: Just bought a replacement inner cam cover. Learning is expensive.
Jims65CA77
Post by Jims65CA77 » Sun Aug 12, 2018 10:25 am
garncarz wrote:Learning is expensive.
Ouch, sorry to hear that, but yeah... we've all been there and learned 'things'. I busted the Oil Filter on my Dream trying to get it apart to clean it. Then... after I did get it apart, it was perfectly clean inside. Oh well... live and learn I guess.
Jim
Post by LOUD MOUSE » Mon Aug 13, 2018 11:05 am
I can send you a replacement part for $10.00 and $7.00 mail US. ...............lm
garncarz wrote:I should have used Ed's method. I put a gouge in the seal carrier and now the leak went from a drip to a stream. Shit. Any way to seal up a gouge?
