What have you guys done and used to free up stuck carbs?
Thx,
Derek
Freeing Up Carbs on '66 Superhawk
DerekSuperhawk305
Re: Freeing Up Carbs on '66 Superhawk
I put them in my ultrasonic cleaner which has a built-in heater.
The heat and the cleaning effect usually frees up stick slides and help get the carb apart. Once it's apart it goes in again for proper cleaning of all the parts.
DerekSuperhawk305 wrote:.
Thx,
Derek
DerekSuperhawk305
Thanks for the reply...I have thought about getting one of those but, for now I may have to resort to just soaking them...I'm thinking some pure lemon juice or a bit of diesel.G-Man wrote:I put them in my ultrasonic cleaner which has a built-in heater.
Heat is probably the most effective thing as it expands the carb body, reducing its grip on the brass slide.
A hot air gun or a pan of boiling water will do it.
DerekSuperhawk305 wrote:Thanks for the reply...I have thought about getting one of those but, for now I may have to resort to just soaking them...I'm thinking some pure lemon juice or a bit of diesel.G-Man wrote:I put them in my ultrasonic cleaner which has a built-in heater.
Lemon juice is too acidic for aluminum. Don’t do it. It will discolor it. This topic was just discussed last week and someone recommended a heat gun. That solved the poster’s problem. I soak mine in lacquer thinner or use a heated ultrasonic cleaner. G-man’s boiling remedy should work just fine too.
Merz64cb77
Carbs
What about soaking them in ATF and acetone? I did that with the stuck pistons and it seem to do the trick although it took a long time.
67' CB77
66’ CB77
65’ bomber
68’ hellcat
66’ CB77
65’ bomber
68’ hellcat
Merz64cb77
Carbs
67' CB77
66’ CB77
65’ bomber
68’ hellcat
66’ CB77
65’ bomber
68’ hellcat
