JIS screws
kawonda750
JIS screws
Post by kawonda750 » Thu Jan 25, 2018 7:43 pm
I am looking at case screws and am told that they are JIS. I have been restoring Kawasaki triples for years and can get stainless case bolt sets easily. In looking at bolt suppliers on the web, they show JIS as being a different sized head but with standard M threads. Is this correct? Can I use M threads maybe with hex heads?
rrietman
Post by rrietman » Fri Jan 26, 2018 12:42 am
yes and yes. you want the right ones go to McMaster Carr for JIS head screws. you want the wrong ones any old 6mm will do.
Good luck
Randy
jkv357
Post by jkv357 » Fri Jan 26, 2018 9:27 am
I believe there was a time that Honda used JIS screws with a now non-standard thread pitch, so depending on the year an original 6mm JIS screw may not match a current M6's pitch.
Anyone know anything about that?
Tim Allman
Post by Tim Allman » Fri Jan 26, 2018 9:46 am
jkv357 wrote:I believe there was a time that Honda used JIS screws with a now non-standard thread pitch, so depending on the year an original 6mm JIS screw may not match a current M6's pitch.
The change to ISO happened in the late 60s. Several screw sizes were affected but not the 6 mm ones because the two standards are essentially the same. So, any current 6 mm screws will work.
JoeM
Post by JoeM » Thu Feb 22, 2018 12:25 pm
I tackled the whole JIS issue some years ago. Further discussions here
https://fourwheelforum.com/showthread.php?t=1924
