Can't find my key! Need a new main switch with key :/
3030vision
Post by 3030vision » Sun Sep 10, 2017 7:33 pm
So got my 1964 CB77 cleaned up, got a new battery in and charged and... WHERE'S THE KEY?
Ugh. Do I have any alternive besides replacing the main switch? Any leads in where to find one of those?
So frustrated.
jkv357
Post by jkv357 » Sun Sep 10, 2017 10:12 pm
Does the ignition have numbers on it? You can get a key if you have the numbers.
I'm pretty sure there weren't many different lock cylinders back then, so a search on ebay should be all you need to get a key.
3030vision
Post by 3030vision » Mon Sep 11, 2017 1:33 am
jkv357 wrote:Does the ignition have numbers on it? You can get a key if you have the numbers.
Yes, it does have numbers on it and low and beyond I found a key online that supposedly matches. As I mentioned in a previous post, I find this too good to be true but I'll be purchasing that key and trying it out.
Fingers crossed!
Merz64cb77
keys
Post by Merz64cb77 » Mon Sep 11, 2017 5:36 pm
I ran into the exact same problem with my 67' CB77. In my case the ignition number was T1644 and I found the key via this ad. He has over 1000 keys for vintage honda bikes. Check for your number on his posting.
But if you found the key number online I'm sure it would work or maybe I was just lucky in my case.
http://www.honda305.com/forums/vintage- ... 36862.html
67' CB77
66’ CB77
65’ bomber
68’ hellcat
Tim Allman
Post by Tim Allman » Mon Sep 11, 2017 5:54 pm
This is something a locksmith can deal with as well.
Post by e3steve » Tue Sep 12, 2017 1:48 am
Fingers crossed!
If the numbers match, the key will work...
3030vision
New keys don't work
Post by 3030vision » Thu Sep 14, 2017 5:55 am
Just a quick update: I ordered 3 new keys on eBay (can't be too safe) and none of them work. At this point I'm not sure if they keys were cut incorrectly or if there's an issue with my switch (assuming the former for now). Currently looking to source some older keys...
The search continues :/
