I'm trying to reinstall the header pipes on my '67 CA77 Dream and am having a problem. No matter how I try to attach them I can't seem to get enough clearance for the chrome brace near the bottom of the front fender. Maybe I didn't pay enough attention when I took them off. I've tried everything I can think of here, is there a trick to it?
Any and all advice would be greatly appreciated. Thanks.
Fender brace hits the header pipes
I can't seem to get them mounted without the brace hitting the pipes when turning the fork. The best I can do is have them at an angle so the brace barely hits the pipes when turning, but then if I take the bike down from the center-stand the problem is worse - can't ride the bike that way, can barely steer at all.
Maybe where they bolt into the cylinder head has to be at an angle instead of flush? Seems like they were flush against the head when I removed them. I've tried about everything I can think of.
So,here are my thoughts. If you are replacing the header pipes you took off and everything was ok then it should fit back now. The flange on the headers needs to seat properly on the copper washer. This might seem a dumb question but are you fitting the correct header to the correct side. On my 77 there is about 1/2" between the header and the brace.
What I can't understand is if it was ok before you took things apart things should fit back now.
Have you put a different design brace on??
OMG ... I'm an idiot. I guess I was trying to put the left pipe onto the right side, they look absolutely identical to me. Thanks for the help casamere & ggarton, all is well now.
