High Altitude Riding
norman
Post by norman » Wed Apr 12, 2017 6:03 pm
Hi, I was wondering, is there a rule of thumb about carb. jet size for high altitude riding ? It will between 6,000 and 12,000 feet I will be riding a CL-77 . Thanks Norman
Geeky160
Post by Geeky160 » Wed Apr 12, 2017 6:51 pm
I don't remember about the jets but my CL77 was a dog at 12,000 Ft. 3% HP loss per 1000 feet is what I do remember. I run stock jets here at 6500 though.
norman
High Altitude riding
Post by norman » Thu Apr 13, 2017 4:00 pm
Thanks Geeky, I figured smaller jets would help ,I just don't know where to start
Post by G-Man » Fri Apr 14, 2017 10:48 am
You could try dropping the needle a notch and seeing what happens. That won't affect the wide open jetting but it might help you work out what to do .
http://cdn.powerequipment.honda.com/pe/ ... i54675.pdf
marzini
Post by marzini » Fri Jul 28, 2017 4:57 pm
+1 for G-Man's recommendation. That's what is working for me after a lot of experimentation.
Some have recommended #120 or #125 main jet above 5k feet for the CB77, but that's not what is working for me so far.
I would have figured changing to smaller main and slow jets would be a given, but (at 6~7k feet) I'm finding that just a drop in the needle one notch from stock (leaner) seems to be working for me so far. My '62 CB77 is stock except for Dunstall reverse-cone mufflers and K+N RE-0240 air filters mounted on short radius 1.5" diameter radiator hoses I got from Napa.
My main jet is #135 (I tried a #125 and #130). The slow jet is #42 (I tried a #38).
There was a big difference (improvement) just raising the needle from the 2nd notch from the top to the middle slot (richer) with the #135 main jet in place. I was all over the place on the needle with the various slow and main jet changes I tried. Raising the needle another notch is back to the stock setting as recommended by the masters.
LM (at 6k feet) said his CB77 uses #135/#42/2nd notch from the bottom which is the same as Bill Silver's tune-up recommendation.
'62 CB77, '76 XT500
rrietman
Post by rrietman » Fri Jul 28, 2017 8:26 pm
off topic a bit but interesting. I have a bike that the ecu stops working at 8000 ft. shuts down. anybody have a guess?
Randy
brewsky
Post by brewsky » Sat Jul 29, 2017 3:34 am
1. pre recall FJR?
2. Sensor problem?
