OK, here's the scenario - trying to get the PITA stator on the crankshaft of the CA95 I'm rebuilding, I tried and tried to get the woodruff key to stay into it's little slot in the crankshaft.
Every time I tried to insert the generator/magnet and tighten it down via the spark advancer bolt, the woodruff key would not (appear to) stay in it's slot.
Previously, I had been able to do this with Much effort, but It Had Been Done.
A little backstory here - I had a massive air leak through the valves, so had the valve seats reground and new valves inserted- sucker's now pulling 150 lbs pressure on both chambers, and I had high hopes to be able to put it back together today and hopefully start it.
Back to Today - Long story short, I noticed in between my efforts that both the stator sprocket AND the rear face of the stator housing have more cracks in them than Betty White's hip...
Did *I* do it, trying to crank down on that (and please excuse the expression) GODDAMN woodruff key...? Try as I might, that damn generator/magnet would NOT bolt down w/o pushing that damn key back and out of it's slot, sliding it up and seemingly out of it's channel...
Previously, I (*thought ) I got everything aligned, and would tighten the spark advance bolt tighter and tighter until *Pop! it would slide into place, or so I believe.
My Question, is (1) should it be that effing hard to get the generator/magnet into place/was I doing it wrong...? Should it 'pop' into place, and (2) was I doing it wrong and screwed it up myself?
How is it possible to crack both the stator sprocket AND the stator housing? In multiple places??
And my last question: anybody have a stator/generator set-up, housing and/or sprocket they don't need? And if so, for how much? And how do you get the stator OUT of it's housing w/o tearing it up??
Any insight is much appreciated...
-John
CA95 - Well, I fcked up, I think...
Dr. Frankenstein
- Tim Allman
Dr. Frankenstein
