Broken CB77 tool box
akpasta
Post by akpasta » Wed Dec 21, 2016 5:46 pm
Hi Folks,
1964 CB77 and I noticed yesterday the side-cover mounts on my tool box have snapped off the tool box. Replacements on ebay that aren't also broken or covered in rust appear to cost $50-$120. Has anyone ever attempted a repair of this item? I'm not sure if it's steel or aluminum but my first thought was to get a piece of flat metal about 2"x3" and jb weld it to the inside of the tool box and mount, and use it kind of as a joint or something. Does that make sense? Anyone else have a repair to try?
Seems like the thin metal on the tool box is a recipe for broken side cover mounts.
pemdoc65
Post by pemdoc65 » Wed Dec 21, 2016 10:48 pm
I MIG welded mine back together, ground down the welds and repainted. They seem to be holding. A small plate welded to the backside of the mount (inside the box) would provide added strength. This is a pretty common problem. On one of my other bikes, I ran a bead of weld around the tab that mounts to the box before it had a chance to crack.
akpasta
Post by akpasta » Thu Dec 22, 2016 11:59 am
Unfortunately I do not weld.
Goodysnap
Post by Goodysnap » Fri Dec 23, 2016 9:16 am
akpasta wrote:Unfortunately I do not weld.
So take it to someone that does.
Mig welding is going to be the only worthwhile repair option for your situation. I suppose Brazing may work OK as well.
64' CB77
65' CB160
Tim Allman
Post by Tim Allman » Fri Dec 23, 2016 11:05 am
Goodysnap wrote:Mig welding is going to be the only worthwhile repair option for your situation. I suppose Brazing may work OK as well.
I had to have this repair done many years ago and brazing worked (and continues to work) well. Clearly this is a stress failure and the rather large amount of bronze used has likely spread the stress and reduced the strain on the sheet metal.
Goodysnap
Post by Goodysnap » Fri Dec 23, 2016 11:54 am
Tim Allman wrote:I had to have this repair done many years ago and brazing worked (and continues to work) well. Clearly this is a stress failure and the rather large amount of bronze used has likely spread the stress and reduced the strain on the sheet metal.
I agree that brazing does tend to work better on thinner metal repairs. That thin steel is difficult to work whichever you choose. If rusty even worse yet.
64' CB77
65' CB160
