jetting for straight pipes?
Richard305
Post by Richard305 » Mon Jul 04, 2016 12:48 pm
What would be approximate correct jetting for 1967 CL77 with straight pipes (no baffles) Altitude is 700ft around here.
Nick
Post by Nick » Tue Jul 05, 2016 11:27 pm
Probably be fine with stock jetting, but see what the plugs have to say. One size larger may be needed.
Re: jetting for straight pipes?
Post by LOUD MOUSE » Wed Jul 06, 2016 6:24 am
Back about 1994 I was breaking in a CB77 and a CL77 after a complete bike/engine rebuild.
The CB77 was easy to start and warm up then ride.
The CL77 would snap and pop until hot then ran OK.
I considered the actual difference between the two bikes and engines and felt the only actual difference is the exhaust.
So I jet the CL77 carbs same as the CB77 carbs.
Problem solved and to this day I jet the CL77 same as the CB77. ....................lm
Richard305 wrote:What would be approximate correct jetting for 1967 CL77 with straight pipes (no baffles) Altitude is 700ft around here.
Richard305
Post by Richard305 » Sun Jul 10, 2016 8:55 am
Thanks for your help
Post by LOUD MOUSE » Sun Jul 10, 2016 9:05 am
You are welcome.
I hope I helped. ..................lm
Richard305 wrote:Thanks for your help
malcolmgb
Post by malcolmgb » Mon Jul 11, 2016 2:23 pm
Apologies for hijacking this thread but rather than starting another similar;
I have a CL72, when the carbs were stripped I found #130 Main jets and #42 Slow jet, the Honda manual I have says #125-130 Main, #40 Slow, I have seen in the Bill Silver book different sizes again.
To complicate matters further the pistons/cylinders were +3mm giving an engine capacity of 276cc, maybe that was the reason for a difference, it is now back to std bore size, any thoughts advice welcome.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Post by LOUD MOUSE » Mon Jul 11, 2016 2:47 pm
If you don't have the HONDA recommend jets I think I can help. ..........lm
malcolmgb wrote:Apologies for hijacking this thread but rather than starting another similar;
