CL77 FRONT FORKS AND STEERING STEM
PMPiper
Post by PMPiper » Mon Apr 11, 2016 10:01 pm
I'm just getting started on 2 bikes I've had for 25 years so I'm starting with baby steps. I'm starting with the Forks of 2 CL77'S. Is there a supplier for the internal O-Rings beside original Honda parts? Second question. Has anyone come up with a different bearing system for the steering stem besides the loose bearings used originally.?
Post by Seadog » Tue Apr 12, 2016 8:01 am
There are probably other sources, like ebay, but have you tried CMS?
http://www.cmsnl.com/honda-cl77-scrambl ... partslist/
Re: CL77 FRONT FORKS AND STEERING STEM
Post by G-Man » Tue Apr 12, 2016 12:07 pm
You can use the search facility on this site to search for a particular topic or use google.
http://www.honda305.com/forums/taper-st ... 35225.html
PMPiper wrote:I'm just getting started on 2 bikes I've had for 25 years so I'm starting with baby steps. I'm starting with the Forks of 2 CL77'S. Is there a supplier for the internal O-Rings beside original Honda parts? Second question. Has anyone come up with a different bearing system for the steering stem besides the loose bearings used originally.?
PMPiper
Post by PMPiper » Wed Apr 13, 2016 12:02 am
Thanks for your tips. New at this forum stuff.
Post by G-Man » Wed Apr 13, 2016 12:51 am
You're welcome. Put your location in your profile and you might find some helpful folks in your area.
PMPiper wrote:Thanks for your tips. New at this forum stuff.
malcolmgb
Post by malcolmgb » Fri Apr 15, 2016 2:19 pm
For the steering stem I used a kit from All Balls Racing.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
