Spark plug wire replacement
Woodsie
Post by Woodsie » Thu Feb 11, 2016 7:59 pm
How do you get the plug wires out of the coil
DianneB
Post by DianneB » Thu Feb 11, 2016 8:44 pm
In most cases, you don't - they are molded in. On some replacement coils, the spark plug lead screws into a socket and pin in the coil. Look VERY carefully where the lead goes into the molded body and see if there is a very tiny gap between the wire and the body - if not, you are out of luck.
You should be able to buy a "spark plug lead splice" at better auto parts stores.
Woodsie
Post by Woodsie » Thu Feb 11, 2016 8:54 pm
Thank you very much for the reply. It appears my choices are to buy a new coil with leads or the splicer.
Nick
Post by Nick » Thu Feb 11, 2016 10:03 pm
Not so fast.... Can't remember where it was posted (perhaps here) but there was an in-depth post on how to cut away part of the coil molding where the wires go in, remove the wire and replace with new wire, and then seal it all up again with JB or something similar. Seemed like a pretty simple job.
Might be worth a try.
Woodsie
Post by Woodsie » Thu Feb 11, 2016 10:19 pm
Thanks for the tip Nick. I'm going to look into that. I will post the results
Woodsie
Post by Woodsie » Thu Feb 11, 2016 10:50 pm
Just took the coil off and underneath was a hard glob of something under each wire. I chipped it off and there was a what appeared to be small diameter hole filled with this stuff. I drilled it out and with a bit wiggeling the wires pulled out. There is a spike at the bottom. I am going to get some plug wire, try to push it in.
DianneB
Post by DianneB » Fri Feb 12, 2016 6:09 am
Woodsie wrote:There is a spike at the bottom. I am going to get some plug wire, try to push it in.
You got it! Those little spikes should have a very fine thread that will dig into the centre of the plug wires. Don't use JB Weld. If you want some seal/support for the wires, screw the wires in and just use a little hot glue where the wires meet the coil body - it is very pure and wont cause arcing.
