Top crankcase half upside down, right side -
This appears to be an oil passageway, how tricky is it to put crankcase sealer here?
Oil passage...
Oil passage...
- oil passage 002.JPG (77.53 KiB) Viewed 2630 times
Re: Oil passage...
Put it on the lower case. .............lm
R100 wrote:Top crankcase half upside down, right side -
Re: Oil passage...
Thanks LM.LOUD MOUSE wrote:Put it on the lower case. .............lmR100 wrote:Top crankcase half upside down, right side -
Do you do all the crankcase sealer on the lower case?
Any pitfalls in doing it that way?
Re: Oil passage...
I do apply the sealer (HONDABOND 4) to the lower case and be sure to put some at the 2 studs which are in the middle. ...................lm
R100 wrote:Thanks LM.LOUD MOUSE wrote:Put it on the lower case. .............lmR100 wrote:Top crankcase half upside down, right side -
Re: Oil passage...
Got it, thanks.LOUD MOUSE wrote:I do apply the sealer (HONDABOND 4) to the lower case and be sure to put some at the 2 studs which are in the middle. ...................lm
\R100 wrote:Thanks LM.LOUD MOUSE wrote:Put it on the lower case. .............lmR100 wrote:Top crankcase half upside down, right side -
