Any locksmiths in the house?
DianneB
Post by DianneB » Mon Jul 20, 2015 5:52 pm
I have a '67 C77 with 6 position ignition switch and bought a replacement key.
I understand that the key should only come out in 2 positions but I can remove the key in all 6 positions.
What, specifically, is supposed to stop the key from being withdrawn in 4 positions and let it be removed in 2 positions?
Do they do this with 3 piece pins?
(I have some understanding of how locks work.)
HELP!
Yasojaki
Post by Yasojaki » Thu Aug 13, 2015 12:29 am
Want to bring this information to publish in various media.
Vilstant
Post by Vilstant » Fri Sep 22, 2017 6:22 am
So far as i can see your replacement key is not usable. A locksmith http://locksmithvaughan24.ca cut another one from a blank and i have no issues with my '76 Honda.
allencooper
Post by allencooper » Tue Oct 10, 2017 1:50 am
Vilstant wrote:So far as i can see your replacement key is not usable. A locksmith http://locksmithvaughan24.ca cut another one from a blank and i have no issues with my '76 Honda.
Having key cut from a locksmith is cheaper then going to the dealer. You have chosen the right option to get the new key.
Tim Allman
Re: Any locksmiths in the house?
Post by Tim Allman » Tue Oct 10, 2017 10:51 am
DianneB wrote:I have a '67 C77 with 6 position ignition switch and bought a replacement key.
HELP!
I had this problem once. Honda locks from the era are not especially robust and mine became so worn that the key could be removed in any position and with a little patience I could turn the core with a screwdriver. Replacement was the only option.
In a pin tumbler lock that works properly the upper and lower pins are sized such that a key will cause all of the pins to align with the top of the core and allow the core to turn. (http://lockwiki.com/index.php/Pin_tumbler) In this position the pins are held in position and prevent withdrawal of the key. I suspect that in a lock with two positions that allow the key to be inserted or removed there is a second set of upper pins at the second position.
jacksmith12
Post by jacksmith12 » Thu Oct 12, 2017 9:58 am
Last night i come in trouble with front door lock as i tried to open it but the lock won't open. Then i visited find nearby locksmith site to find the locksmith near me, there i have found many locksmiths near in which i have called one for the emergency. They immediately came to the spot and fix the lock issue.
OdisJohnson
Post by OdisJohnson » Fri Oct 20, 2017 2:42 am
There are many ways to get the locksmith but always choose the one which offers instant service at reasonable prices.
