K/S Bush ?
SMBH
K/S Bush ?
Post by SMBH » Thu Jun 11, 2015 3:37 am
I always seem to have problem with the Honda parts numbers I have purchased a bush of David Silver UK https://www.davidsilverspares.co.uk/CB7 ... rt_230849/ Will this fit my 1964 CB77 engine number CB77E 102472 .
This David Silver bush starts from engine number CB77E 1043041 that's 7 digets mine has 6 what year is that 7 digit number ?
For such a company as Honda for me they had a bad engine numbering and parts book system not easy trying to understand them.
EDIT
Just had a reply from my email I sent to David Silver and they do not know what year the bush fits they say it will not fit my bike DID Honda make different low gear bushs then, please can some one confirm this as I have my order on hold. Thanks.
Post by G-Man » Thu Jun 11, 2015 9:58 am
Mike - number sequence in the list below.
R100
Post by R100 » Thu Jun 11, 2015 10:39 am
G-Man:
I copied that.
If there is a next page for the following years, would you mind posting a pic.?
My engine is a CP number, so finding the correct version of the odd part can be mysterious sometimes.
Post by G-Man » Thu Jun 11, 2015 11:26 am
R100
That's all there is. The numbers just run on in sequence after the beginning of 7-digit numbers. e3Steve and others have mapped users frame number on to year of manufacture but there's nothing official that I know of.
SMBH
Post by SMBH » Thu Jun 11, 2015 1:29 pm
Yep I have that, so engine number CB77E 1043041 is post 1964 no wonder David Silver could not tell me the year.
I purchased a new bush from here http://www.classichondarestoration.com/ ... od_66.html now this bush has done only say 300 miles and seems to me warn I have a original bush looks like it was made of bronze the repro one looks like copper.
I have installed a new kick start spindle and the repro bush when the spindle is rotated in neutral the low gear just wobbles is this how it should do.
Post by G-Man » Thu Jun 11, 2015 1:40 pm
Mike
The bush should be made of bronze but there are different types of bronze ranging from almost a yellow (brass-like) to to a copper-colour. It should be a good running fit on tha shaft and in the gear so it shouldn't wobble.
This a 1961 type bush bead blasted and ultrasonically cleaned.
This is the 1961 type and a NOS genuine Honda bush for later engines
SMBH
Post by SMBH » Thu Jun 11, 2015 2:00 pm
Top one some 300 mls from classic Honda restoration bottom one warn gen Honda taken off bike. Your bush ridge looks a lot thicker than mine G-Man, how thick would you say it is not including the slope I will try and get one made its gust the ridge that wears.
New one again not good is it.
