Wanted cb77 shifter pedal and linkage, new york
Rysingsun86
Post by Rysingsun86 » Tue May 12, 2015 11:51 am
Does anyone have a cb77 shifter pedal and linkage for sale? Mine came missing. Or are they any alternatives anyone knows of? Thank you
Post by G-Man » Tue May 12, 2015 12:39 pm
They come up on eBay ocasionally. As a temporary measure, almost any Honda shift pedal will attach to the spline.
Rysingsun86
Post by Rysingsun86 » Tue May 12, 2015 4:48 pm
Thank you, you're the man!
pemdoc65
CB77 shift linkage
Post by pemdoc65 » Tue May 12, 2015 9:07 pm
I just purchased the linkage for a CB350 from Ebay for $23.00 Other than the actual shift lever, which has a smaller diameter opening for the bolt, and the end that attaches to the shifter shaft on the engine case, the linkage is identical to my CB77 linkage. It included both end clevises, threaded rod, and the lock nuts.
Re: CB77 shift linkage
Post by G-Man » Wed May 13, 2015 1:00 am
Good idea. A CB400F pedal and linkage might work, too.
pemdoc65 wrote:I just purchased the linkage for a CB350 from Ebay for $23.00 Other than the actual shift lever, which has a smaller diameter opening for the bolt, and the end that attaches to the shifter shaft on the engine case, the linkage is identical to my CB77 linkage. It included both end clevises, threaded rod, and the lock nuts.
cmineo
Post by cmineo » Tue Jun 02, 2015 5:57 am
i have ecerything u need ... shifter and linkage off a 1965 cb77 .... let me know if u still need anything ... pm me
