ca 77 carb rebuild kit
ac72rat
Post by ac72rat » Sat Apr 11, 2015 1:53 pm
G"day who's the parts guru on the forum to purchase carb rebuild kit? thanks , I noticed a wide spread of prices over the net thought I would keep it here along with other parts i will need thanks New guy LINY
Re: ca 77 carb rebuild kit
Post by LOUD MOUSE » Sat Apr 11, 2015 2:17 pm
CA77 carb.
If the bike is running I recommend you reuse all metal parts you have and get a new bowl gasket then do a good wash job. .................lm
ac72rat wrote:G"day who's the parts guru on the forum to purchase carb rebuild kit? thanks , I noticed a wide spread of prices over the net thought I would keep it here along with other parts i will need thanks New guy LINY
ac72rat
Post by ac72rat » Sat Apr 11, 2015 3:42 pm
thanks I would like to use my oem jets etc but cant find just a gasket set ,are there no o-rings besides the bowl gasket
thanks for reply
Post by G-Man » Sat Apr 11, 2015 4:35 pm
Float bowl gasket and rubber gasket under the top cover. There are two different float bowl gaskets. Early 'round bowl' and later 'square bowl'.
http://4into1.com/rounded-float-bowl-ga ... cb72-cb77/
https://www.davidsilverspares.com/CA77- ... rt_230783/
https://www.davidsilverspares.com/CA77- ... rt_230806/
hotrodhendrix
Post by hotrodhendrix » Tue Apr 21, 2015 11:44 am
Well now that I read these everyone is saying use stock jets... I used the jets from the kit. Are they incorrectly sized?
~James
Post by LOUD MOUSE » Tue Apr 21, 2015 12:40 pm
Usually.
Did you compare them?. ............lm
hotrodhendrix wrote:Well now that I read these everyone is saying use stock jets... I used the jets from the kit. Are they incorrectly sized?
~James
hotrodhendrix
Post by hotrodhendrix » Tue Apr 21, 2015 3:55 pm
Honestly that was one of the first things I did about a year and a half ago to the bike. Having issues getting it started right now actually. Im going to do the tuning guide thing tonight now that I got the slide to go all the way down in the carb. Starter doesnt seem to work so on the upside is I am getting used to the kick start lol. This was my first carb to work on so me not double checking sizes is possible.
~James
