Charlie's Place Rectifier/Regulator Wiring
Post by Seadog » Fri Jan 23, 2015 7:09 pm
I've purchased a rectifier/regulator from Charlie's Place and hope that those of you that have done the same can give me some wiring advice.
There are 5 wires to the unit, 3 yellow, 1 red and 1 green. The directions state that red goes to battery pos., green to battery neg. That part is easy enough. However it states that 3 yellow wires on the unit connect to the 3 wires from stator and this is the part that I'm having a little trouble with. 2 of the 3 wires from the stator go to the old rectifier location, but the third, a pink wire, goes to the ignition switch. Can I simply access the pink wire in the wiring harness tap into it?
Also, should I mount the new unit using some sort of heat sink? If so, can those of you that have used it recommend one?
Thanks.
Hahnda
Post by Hahnda » Fri Jan 23, 2015 8:19 pm
I have not used one like this on these bikes. Usually they have only 4 wires one for +, one for -, and 2 for the stator and you splice the yellow and pink together for one and the brown for the other.
The ones on his site look to be 4 wire.
I have used these on various bikes with single phase alternators.
http://www.ebay.com/itm/Tympanium-Elect ... ec&vxp=mtr
Post by Seadog » Fri Jan 23, 2015 10:04 pm
Hahnda wrote:I have not used one like this on these bikes. Usually they have only 4 wires one for +, one for -, and 2 for the stator and you splice the yellow and pink together for one and the brown for the.....
Thanks, Kevin. That 3rd yellow wire has me stumped. I just don't know how or where to connect it to the pink stator wire. I guess it has to be at or before the switch. But what good would that do?
Re: Charlie's Place Rectifier/Regulator Wiring
Post by LOUD MOUSE » Fri Jan 23, 2015 10:30 pm
Call the supplier Charlie. .......lm
Seadog wrote:I've purchased a rectifier/regulator from Charlie's Place and hope that those of you that have done the same can give me some wiring advice.
Thanks.
Post by Seadog » Sat Jan 24, 2015 10:38 am
LOUD MOUSE wrote:Call the supplier Charlie. ...….lm
I will next week; they're not open on weekends. I've also sent an email earlier, but have not received a reply as yet.
mike in idaho
Post by mike in idaho » Sat Jan 24, 2015 11:08 am
You have a three-phase rectifier there, your bike requires a single phase type(two yellow wires).
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
Post by LOUD MOUSE » Sat Jan 24, 2015 11:09 am
That's a bummer. ....lm
