non-detergent oil at Dollar General
I was in Dollar General looking for oil for my truck and noticed they have 30 w. non-detergent oil that's recommended for our Hondas. Very cheap also.
Dr. Frankenstein
Dollar General Oil
And what would the name of said oil be...?
mike in idaho
I think I will use a detergent oil in my stuff, motor oil has evolved quite a bit since 1960. Honda recommends 10-30 motor oil for all-around use for the CB72/77(look in the back of the rider's manual). Non-detergent motor have no cleaning, anti-wear, anti-foaming additives. 10-30 circulates better during cold start-ups and works better in wet clutch setups.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
- Hamamatsu Nippon
Re: Dollar General Oil
How about this "The Generals war on wear Dino no clean 30wt"Dr. Frankenstein wrote:And what would the name of said oil be...?
1967 CA78
1965 CM90
Soichiro Honda
1965 CM90
Soichiro Honda
[quote="Hamamatsu Nippon"][quote="Dr. Frankenstein"]And what would the name of said oil be...?[/quote]
How about this "The Generals war on wear Dino no clean 30wt"[/quote]
Works for me! It's DG brand.
- Tim Allman
I think you are wise and your facts accurate. There is a mythology on this forum that the CB/CL 72/77 require non-detergent oil. I have been digging into the facts and have been able to find only one (not very reliable) source for this myth and much to debunk it.mike in idaho wrote:I think I will use a detergent oil in my stuff, motor oil has evolved quite a bit since 1960. Honda recommends 10-30 motor oil for all-around use for the CB72/77(look in the back of the rider's manual). Non-detergent motor have no cleaning, anti-wear, anti-foaming additives. 10-30 circulates better during cold start-ups and works better in wet clutch setups.
I'll post something more substantial later. Unfortunately my CB72/77 owner's and shop manuals are silent on this but detergent oil is recommended for the CL72/77 in the setup (i.e. initial assembly from crate) manual. Also here is a quotation from the owner's manual of the SL100 (a single cylinder, high revving scrambler from 1970 for which SAE 10W30 is recommended):
More later.NOTE: Non-detergent and low quality oils are specifically not recommended.
