my name is christian form Germany (Munich) and i buy two month ago a CB77
for restauration.
I will say hello to all member of this forum.
My bike need a complete restauration . The work on frame and fork is done.
Today i remounted the revcounter and speedo combination.
Now is the point to take the neadles away.
Can you tell my the secret before i damage something.
Thanks Christian
Remounting revcounter and speedo neadles
Hi Jensen,
thanks for your answer.
The question is : How can i disassembly the needles of revcounter and speedo ?
Are they mounted with a little thread
Are they only put on with preasure
Hallo Jensen, will die beiden Nadeln von Drehzahlmesser und Tachometer demontieren.
Sind die wie bei Yamaha nur aufgesteckt oder mit einer kleinen Klammer oder einem Gewinde mit Mutter unter dem Chromdeckel befestigt?
Habe schon versucht Sie abzuziehen geht aber nicht.
Gruß Christian
Gruß Christian
Guten Tag. Willkommen
The needles are a pressure fit. I have rebuilt a few of these units, and my little secret to removing the needles is to use a pickle fork.
You slide the tines of the fork under the needle, and make sure the base of the fork is resting on the head of a screw that holds the face plate on, and press gently. If they don’t come off on the first try, turn the needles about 90 degrees and try again. They should pop straight off!
Viel Glück!
CJ
'66 CB77
'66 CP77
Viel Glück!
CJ
'66 CB77
'66 CP77
- h305 Moderator
Christian, welcome to the forum!
In which city are you situated? My friend, and forum member, Peter Balzer lives in Hamburg. You guys may be geographically close. balzer.p@online.de
We're all here to help each other.
Mit freundlichen Grüßen!
Steve
Steve
Thanks,
Needles are demounted. Thanks for your help.
Hamburg is 850 km away from my location.
I am from the south of Bavaria near Munich. Maybe you now the "Oktoberfest" in Munich.
This is the home of the short leather trousers and the girls with
colourfull short dresses named "Dirndl". This is the most now from us.
But also we have BMW, Audi,Mercedes an Porsche in the neigborhood.
And the best is we can drive as fast as can on the highway.
Thanks Christian
Thanks Christian
