Which reference do I use for 12 o'clock position on the cam, and is the crank supposed to be on T or F?
Is it 12 o'clock using a level floor as a reference, or 12 o'clock using valve cover mating surface as a reference.
Timing chain marks
Hoosier Tom
gbyoung2
New to the forum, so please bear with me.
Recently picked up a CL77 project bike and after running a leak down test on it, it appears that the RH cylinder has a bent/damaged intake valve. Before I pull the engine, just want to check the correctness of the present cam timing so I can put it back together correctly. From the way the cam cover screws are buggered up, it appears that some PO has been in the engine before.
With the flywheel on the “T” for the RH cylinder, the hash mark on the end of the points cam is facing straight up, i.e., 12:00. Is that correct? If it is, what is the hash reference mark on the end cam cover for?
The mark can be seen in the accompanying images.
And finally, just in case I’m not lucky and have an endless cam chain so that I must split the cam to get the head off, when looking at the points side of the cam, do you turn the cam nut CCW, or CW to loosen it?
Can't seem to be able to attach a pix, but they can be seen at:
http://gbyoung2.smugmug.com/Motorcycles ... 23b-XL.jpg
http://gbyoung2.smugmug.com/Motorcycles ... 24a-XL.jpg
TIA
TIA
gbyoung2
Appreciate it. Assume the "0" shown in the below link is what you're talking about. If the flywheel is sitting on the "T" mark, in you're experience, is the timing of the cam off (retatded) by one tooth?Hahnda wrote:The mark you are looking for is actually on the cam sprocket. It looks like an "0". You have to remove the top cover to see it.
http://gbyoung2.smugmug.com/Motorcycles ... 07a-X2.jpg
More than one. ....................lm
gbyoung2 wrote:Appreciate it. Assume the "0" shown in the below link is what you're talking about. If the flywheel is sitting on the "T" mark, in you're experience, is the timing of the cam off (retatded) by one tooth?Hahnda wrote:The mark you are looking for is actually on the cam sprocket. It looks like an "0". You have to remove the top cover to see it.
gbyoung2
Seriously?LOUD MOUSE wrote:More than one. ....................lm
2? 3?
Whomever put this thing together previously did not align the master link with the "0", but the actual cam mark only looks to be about one (1) tooth off.
