Electric Start Free Spins Help Please
I went to crank up the CB77 and the electric starter free spins and does not turn over the motor then every once in a while it will catch and try to turn it over but it will crank up everytime kick starting it. Any idea what it might be
Thanks, Chad
Thanks, Chad
- h305 Moderator
Almost certainly needs the starter clutch servicing. Rollers and springs at least, probably caps also -- 3 of each. Cheap as chips from Western Hills Honda.
Come back if you need more info on 'how to'.
Could be a problem within the starter gears, though.
Is there a trick to get the starter clutch off? I know you need the puller where can I get one or is there any way else to get it off.
