Installing rubber knee grips
gopher
Post by gopher » Thu Feb 11, 2010 10:51 pm
What's the best way to install the rubber knee grips on my CL77 tank? Where do you start? How do you stretch the rubber to get it over the mount? It just seems the grips are too small to fit!
mike1969
knee pads
Post by mike1969 » Fri Feb 12, 2010 6:54 am
Try warming them with a hair dryer.
I recently bought a steering wheel cover for my truck and it absolutley would not go on until I heated it really well.
Dgormley
Knee grips
Post by Dgormley » Fri Feb 12, 2010 12:45 pm
Gopher, I submerged mine in warm, slightly soapy water. I did it with the tank on the bike(I tried with it off, no go), starting from the top down. Mine went on fairly easy and look great...........................D
mike horvath
rubber knee grips
Post by mike horvath » Sat Feb 13, 2010 12:09 am
Hey guys,
Did your grips have yet a gap at the top that no matter what you did, the gap remained? I stretched those things every which way and still the gap.
Post by davomoto » Sat Feb 13, 2010 10:45 am
Mike you may need to bend the mounting flange in a bit. The tend to bend outwars when removing the old rock hard grips.
gopher
rubber knee grips
Post by gopher » Sat Feb 13, 2010 3:56 pm
I used the hair dryer to heat the grip and it worked perfectly. Starting from the top also made installation easier. I had a gap at the top when I was finished. I heated the grip up again with the hair dryer and I was easily able to settle the grip into it's proper position.
mike1969
knee grip
Post by mike1969 » Sat Feb 13, 2010 4:08 pm
Glad it worked out for you.
