1968 was the first year for the Z50. That year Honda came out with the Z50 and it had no headlight or tail light. In 1969 they added the tail light and the head light. In 1969 they added a battery and never ever added a battery to any other Z50 after that making the "69 Z50 a rarer Z50 than most. This bike is also a Hard Tail but in 1972 Honda changed there design to a soft tail and kept them that way ever since.
The guy in Vancouver, Canada by the name of Jed that I bought the bike from was a motorcycle tech so he was kind enough to dismantle the thing and ship it across the country to me. (Thanks Jed)
I have to admit the bike was in rough condition. The frame had three cracks in the welds which was easy enough to fix. The welding on these bikes from the factory would look rough by today's standards so I wouldn't Tig weld them because it would look to neat so I just Migged them. You would never know by looking at the frame it was ever welded.
As you can see in the photo's I bead blasted all the metal parts and the frame in in the stand I made when I did the CT70 and I'm doing all the fine body work such as removing any grinding marks that were there from the factory plus and welding slag that was left on the frame and any imperfections that were there before such as small scratches. The bike will be painted a Candy Blue with the tank being two tone blue/silver and base/clear so I need to have it look as good as I can get it.
I have the motor stripped down. Who ever worked on the 41 year old bike in the past had it assembled wrong. There were thrust washers either in the wrong place on the tranny or missing all together. While I have the cases all apart I bead blasted them and painted them as well. All new case bolts and gaskets will be used in the assembly to give the motor that new fresh look.
Also with the motor the chain case guard was cracked and Honda One got that and all new wheel bearings plus bolts on the way to help with the restoration. Someone decided after the spline wore out on the kick starter to weld the kick starter directly to the kick starter shaft so I had to cut that off and install a new kick starter shaft.
I rebuilt the cyl head. New valves, honed the cylinder and bead blasted both parts then painted them. I'm waiting on parts from everywhere. New picton, rings, timing chain, timing gears, oil pump gear, gasket kit and seals. There coming from as far as Australia, Thailand, the UK and Tyler, Texas so that's why I'm doing these items now. The carb has been dismantled and placed in the ultrasonic cleaner. A new kit is on the way for it plus all new clutch disc's so I've bagged everything to keep it clean and prevent anything from being misplaced. All the wheel rims were removed blasted and painted as well and I'm waiting on the new Bridgestone Trail Wing tires which were the originals on the bike when new and new tubes as well.
I did have a little setback. My son came home last week for a visit with his girlfriend and along with there cat and dog and they all went shopping so I had to baby-sit his 7 month little beagle so I lost a day in the shop but I enjoyed being with the little dog so I can't complain. Here's what I got done so far.
The frame being bead blasted :
Cylinder head and cylinder work:
Tranny and cases:
Battery holder:
Carb work:
The rear brake hub had a small piece missing so I had to Tig weld it back and then polish all the aluminum parts:
And this was my special guest. His name is Milo :) He is a house dog and very spoiled :)
Stay tuned!
