Has anyone used this? I am thinking about trying it on my drain plug threads.
http://www.permatex.com/products/automo ... Repair.htm
Thread repair
I second that answer. I've used that Permatex product with near disasterous results on thepiecutter wrote:Helicoil is the only way to go.
oil filter retainer bolt to a Honda 750. The product failed, the oil filter, & cup blew off. I lost all
of my oil, and rear wheel traction after driving through the oil, causing me to dump the bike
right on the entrance ramp of an Interstate highway. I believe if this failure had occured on
the highway, I wouldn't be here to make this post.
"Helicoil" is the only way to go, however beware of the generics. "Helicoils" firmly lock themselves
in place. The generics I've tried, unscrewed with the bolt or plug, and are difficult to reinstall.
You'll never have that problem with "Helicoils".
Stripped threads
Helicoil or Keensert which is a solid thread insert. See link.
http://www.reidsupply.com/aDetail.aspx? ... ead+insert
One other alternative is to use a larger thread drain bolt......I think they go as big as 14mm thread. Auto supply stores have a good variety for generic applications.
Good luck,
Gary
Good luck,
Gary
'65 CL77 Owner
