CA77 front brake hub
Maloymerc
Post by Maloymerc » Wed Mar 14, 2007 3:43 am
Can someone show me an up-close picture of what the stopper or lock that holds the brake cable at the front hub?(the one attached or welded to the hub itself)
Mine was broken off and i need to weld a new one in place before restoring the hub...thanks. Marlon
4shorts
Post by 4shorts » Wed Mar 14, 2007 2:03 pm
Here you go. Hope this is what your looking for. Paul
piecutter
Post by piecutter » Wed Mar 14, 2007 4:25 pm
Had the same problem on my CB77. Ground it down to a flat square base and welded on a cube of aluminum with the hole and slot already drilled through it. Finished it off with a set of files and now you can't tell that it was ever broken.
Michael Stoic
Post by Michael Stoic » Wed Mar 14, 2007 4:45 pm
I am sure you did a very clean install, but are you sure you can trust a weld in this application. There is a lot of force applied to the bracket under hard braking...
piecutter wrote:Had the same problem on my CB77. Ground it down to a flat square base and welded on a cube of aluminum with the hole and slot already drilled through it. Finished it off with a set of files and now you can't tell that it was ever broken.
piecutter
Post by piecutter » Wed Mar 14, 2007 5:10 pm
Absolutely. In fact it should be stronger than the original casting when correctly welded.
4shorts
Post by 4shorts » Wed Mar 14, 2007 5:17 pm
I do allot of aluminum welding here at the shop and in the case of the brake cable bracket I would Tig it and I know it would be strong BUT that being said I would still advise any of my customers to go get a good used part. I just don't like taking a risk for the sake of a few bucks and ones safety. Paul
Maloymerc
Post by Maloymerc » Wed Mar 14, 2007 11:00 pm
Thanks for the pictures Paul! It's exactly what I need.
I guess it is alawys better off to get a replacement for this, but considering the scarcity of parts here, i guess i would have to follow what Piecutter has done.
Marlon
