2nd Honda
modelman
Post by modelman » Thu Jun 14, 2018 1:42 am
Hi G-Man, these are the guys ( its a young lady actually) i've been using for years, she took over from her dad who's now happily retired building model traction engines!!
http://www.metalmagicwheelrefurb.co.uk/
And yes, I thoroughly recommend them, & they have a very good reputation & only 3 miles from me.
Brian & the girls are very busy at Prestige & I had to wait over 4 months this time, but since I'm only 10 miles from them, if you give me a bell with your arrival time & i'll pop across for a coffee & a sticky bun!!
PM sent with mob No.
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
joey7478
Post by joey7478 » Fri Jun 15, 2018 11:29 am
Geoff Hastings wrote:Hi there, I Had the same parts missing from bike, for the chain guard, having dismissed the £250 asked on eBay I looked for a cheaper alternative. What I ended up with was a brand new chain guard for a cb125 for £20. The top half fitted with almost no mods, just needed to relocate two of the holes. The lower half needed a strip about 30mm added to its length. It looks ok but if you look closely you can see the join is upside down but I can live with that. The carb covers were another problem so I bought a sheet of 3mm ally and after making a cardboard template managed to fabricate a passable replica. With a skim of filler and a coat paint they look fine, total cost was about £8.
What year cb125 did you get the chain guard from?
Geoff Hastings
Post by Geoff Hastings » Fri Jun 15, 2018 11:42 am
Sorry, I can't be specific on the year of the bike, I just did a search of chain guards until I saw a likely candidate. It was a cb125 but they made them for many years, the top half virtually fitted with no mods except to relocate the mounting holes. The lower half needed a strip, full length of the guard about 30mm wide welded on. It is a lot more flimsy than the original metalwork but once it is mounted it's fine.
Geoff Hastings
CA77 Chain guard substitute.
Post by Geoff Hastings » Sun Jun 17, 2018 4:18 am
Sorry I misled you, I did a search of my eBay purchases and found the chain guard I bought, it is from a Honda Innova ANF125 2003- 2009 and I got it from MAX-HONDA-SPARES and cost £24.99
joey7478
Re: CA77 Chain guard substitute.
Post by joey7478 » Wed Jul 04, 2018 1:18 pm
Thanks joey!
modelman
Post by modelman » Thu Jul 05, 2018 11:07 am
UNBELIEVABLE!!
I can't believe my luck, after a total nut & bolt rebuild, I just guessed the timing & ignition, & using a tiny little lithium-iron battery, put fuel in, switched on, pressed the starter & she was running before I let go, nice & smooth, with an even tickover, & absolutely everything was working just fine.
I had to completely alter the original wiring loom & alternator as I fitted new L&R switch gear consisting of a left assembly with hi-lo, horn & indicator switch, then a R/hand unit comprising lights off/on/main, & starter button, this right unit included the twist-grip so the original helix assy had to go!!
Full alternator output now feeds into a solid-state regulator/rectifier, also fitted an adjustable-rate flasher unit.
My home-made carb-cover (No.6) 'almost' fits, No.7 coming up!
Also managed to 'alter' (cut & re-weld) the pattern silencers from hanging-down to hanging-up!
https://www.dropbox.com/s/ul7qpbqin1vka ... 1.jpg?dl=0
https://www.dropbox.com/s/lbnrgup4yp68c ... 2.jpg?dl=0
https://www.dropbox.com/s/1ruadu5xsyxle ... there3.jpg?
https://www.dropbox.com/s/3ybobd0nv2044 ... there4.jpg?
https://www.dropbox.com/s/c8bg86xtq6jwy ... 5.jpg?dl=0
https://www.dropbox.com/s/ihewf9tncnrt2 ... 6.jpg?dl=0
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
Geoff Hastings
Post by Geoff Hastings » Thu Jul 05, 2018 12:01 pm
Excellent job, shame about the silencer fit, like you, I had to compromise with my silencers. I'm currently using a short megaphone type until I find either some originals or good pattern ones.
