Tytronic electronic ignition help?
David M. Lyon
TYTRONIC installation on CB/CL 72/77
Post by David M. Lyon » Sun Aug 27, 2017 8:01 am
I have a short video on YouTube of how to install the TYTRONIC ignition kit. The original instructions are impossible to follow so I made a set of instructions that might help you and a wiring diagram.
https://youtu.be/yKPwMUnbRU8
Tytronic wiring.jpg (34.85 KiB) Viewed 3933 times
Dr. Frankenstein
Post by Dr. Frankenstein » Sun Aug 27, 2017 8:25 am
Dave, you Rock, man! :)
I will try this soonest and let you know how it goes; thanks!
Tim Allman
Post by Tim Allman » Sun Aug 27, 2017 9:15 am
From the Tytronics web site:
- Quick and simple installation that is easier than installing a set of points!
- the best, simplest, and most complete installation instructions in the industry.
It's amazing how much marketing can change one's perspective.
David M. Lyon
Post by David M. Lyon » Sun Aug 27, 2017 9:47 am
Here are the instructions I revised to install the TYTRONIC ignition kit.
Installation instructions combined.jpg (251.44 KiB) Viewed 3925 times
Tim Allman
Post by Tim Allman » Mon Aug 28, 2017 8:58 am
Yikes!
David M. Lyon
Post by David M. Lyon » Mon Aug 28, 2017 6:02 pm
Is this posted in the wrong forum? should it be in the electronic ignition upgrade post???
jdmachinist
Tytronic Electronic Ignition problems
Post by jdmachinist » Sat Jul 21, 2018 5:21 pm
David M. Lyon wrote:Here are the instructions I revised to install the TYTRONIC ignition kit.
Thank you for posting these instructions!
I installed a Tytronic Electronic Ignition on my 1965 CA77.... used the instructions supplied, not good but would get someone in the right direction.... i also used these which was a lot easier to understand.
After mounting and wiring everything up, it did not work :-(
Using a Test light to set timing, the light stays on the whole time. I was wondering if that was just a fluke, so i spun the motor and no spark at all.
Just messaged "Old_Honda" on Ebay. Going back to points for now so i can ride when the rain stops.
It is frustrating that i had to wait 2 weeks to get this from China then it was a bad one.
hopefully better luck next time.
