66' Scarmble Project
Dick Eastman
Post by Dick Eastman » Wed Jan 06, 2016 10:48 am
The close-ups really showcase the superb attention to detail - big kudos! there are so many nice touches - especially like the rear sets and the use of Heim joints - are they rt and lh threads for adjustment? Gonna use those on mine, as well. Like the use of S/S hdwr. More details on your Amals and megaphone, please.
Beautiful and well executed job!
moondoggers
Post by moondoggers » Wed Jan 06, 2016 6:25 pm
The Heim joints are std thread. The carbs are Amal 626-301 w/ chokes and used the std Honda throttle cable and splitter.
Amal 626-301 w/chokes
Dick Eastman
Post by Dick Eastman » Fri Jan 08, 2016 6:03 am
It appears your chokes are cable operated, and you used a second oem throttle cable for operation? Choke lever set-up?
How close was the jetting on the Amals, as purchased?
moondoggers
Post by moondoggers » Sat Jan 09, 2016 4:32 pm
You can see the choke lever on the left side of the handlebars. The OEM split cables for the carburetors are short by about an 1/8", not letting the slides seat on the adjustment screws so we are having a pair made.
The carburetors came stock with #2.5 slides 160 main jet and 106 needle jet, running too rich, we bought a # 3.5 slide which leaned out the mixture, when the inclement weather clears we'll do more road testing.
Choke lever
Choke lever
honda resize-019.jpg (217.2 KiB) Viewed 5069 times
bill440cars
Post by bill440cars » Sun Feb 07, 2016 12:45 pm
Been quite awhile since I was on board here and just managed to get back on. Saw this thread and thought I'd check it out AND, am I glad I did!! This is One Mighty Awesome Build!!
The details of this build, are so much, to take in. I am going to have to REALLY look this one over!! Awesome Work!!
Working Toward Being Able To Work On MY Motorcycle Projects (Trying To Get Past "Other" Projects & I Think I Am Making Progress?
OldScrambler
Post by OldScrambler » Wed Feb 10, 2016 9:51 pm
Very very NICE!
Anything special in the motor?
moondoggers
Re: what's in the motor
Post by moondoggers » Thu Feb 11, 2016 8:20 pm
Thanks for comments, she "Scarlet" is a beauty. Inside the motor is a Bore-Tech 358 kit, R/D valve spring kit for Honda 305, Charlie's Place Electronic ignition and a Barnett clutch . Valves are stock as is the cam. Transmission gears are X'd and I'm looking for a 16T front sprocket to to compliment the 37T at the rear.
Still breaking in the motor, so much fun to ride won't be long before I can do an extended ride.
