Steve,
My mufflers do not have drain holes. Are drain holes needed if the bike is kept in a garage and never ridden in the rain?
Phil
New member w/1966 CB77 restoration
If a bike is run for a short period there is moisture in the muffler. Shut it off then and that moisture settles in the muffler, hence the drain hole.
After it has been run hot for a while ( full op. temp.) the moisture gets dissipated and inside the muffler is dry.
Also, moving it from a cool environment into warm humid air cause condensation. Think of a cold beer glass on a humid day.
I think a drain hole at the lowest point is a good idea.
(Just my humble opinion.)
Hoosier Tom
I recommend you drill a hole for the moisture to exit or the moisture will gather and become caustic and make it's own hole which you won't be pleased with!. ...............lm
philrock wrote:Steve,
Phil
